Stock head unit allright?
Username: Ffxdevilarms
Post Number: 7
I am going to get a 2004 honda civic. I plan to put a 13w7 and a jl audio 1000.1 amp. Will i need to get a different head unit then the stock one? or will it not sound very good. I plan to get more then just the sub, but i havent made my mind up on wich other speakers to get.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 4335
you can use the stock unit at first, but ideally, I'd get rid of it and go to something with a good 4V pre-out line voltage, MP3 support, etc., and add a 4 channel amp and component speakers for an all around good system
someone is setting that W7 and amp in the amplifiers forum.
go check it out
Post Number: 8
i know very little about car audio, what exactly is a 4v pre-out line voltage and why is it a good thing to have in a system. I have now decided to go with a 2004 grand am because of price issues, so would that make a whole lot of difference in my set up. Also, what would be a good head unit that would fit in a grand am that is an extremely reasonable price?
