Remote wire
Username: Rsmartinez
I'm not sure if I hook up my remote wire from my harness to my radio and amp together. Or just hook my remote from amp just to my radio.
Username: Jerzyboy246
Can I hook up my amps remote wire to the acc wire
Username: Musicman625
your amp hooks directly to the battery, but you can use any switched 12 volt source for the remote 12v
Need to Register?
Forgot Password?
Enable HTML code in message
