Need amp specs please
Username: Bstephens157
I just bought two JL 12 inch subs. They are rated 8 ohm 50-50 Watts. They came with a Kenwood KAC 7202 amp which has these specs..
Continuous Power / Channel Qty
150 Watts x 2
Frequency Response
5 - 20000 Hz
Signal-To-Noise Ratio
100 dB
Amplifier Output
2-channel
Output Power / Total
920 Watt
High Level Inputs
Yes
Input Signal Voltage
0.2 - 5V
Amplifier Output Details
Output Power / Channel
150 Watt, 230 Watt, 460 Watt
Output Impedance / Channel
2 Ohm, 4 Ohm
Frequency Response
20 - 20000 Hz, at 1 kHz
Total Harmonic Distortion (THD)
0.08 %, 0.8 %
Supply Voltage
14.4V DC
Channel Qty
1, 2
I don't think this is the right amp since at 8 ohms I think the amp would only put out 75 watts per channel.
Can anyone help me select what type of amp I should be looking for. It sems none of them list much concerning 8 ohm speakers
Need to Register?
Forgot Password?
Enable HTML code in message
