Kenwood amp problems
Username: Xmrider282
I just finished setting up my Sub with my kenwood kac-5001ps to test and everything worked great. So then I decided to move it into place (which was behind my seat) and had to disconnect the wires running from the amp to the sub ( which is a kicker comp R) and realized I wired it backwards after I turned it on to check if it worked. It obviously didn't work so I looked at it and switched it back but now my sub won't work and my the power indicator on my amp just blinks between bright and dim. I am not sure if I should take it back to get fixed or if I there is something I can do to fix it at home. Thanks for the help
Username: Kpa2727
Old Bridge, NJ USA !
Post Number: 1652
if you reversed the power wires to the amp, you probably blew the amp's fuses. they plug into the side of the amp, those are in there for this type of reason. see if their blown if they are replace with the exact amp fuse and you should be good. otherwise possible the remote wires disconnected.
