Car GPS have quite an impact on battery drain
Username: Toniwo
I've recently remembered that my car has a GPS tracker device fitted (incase it ever got stolen) and I've heard they can have quite an impact on battery drain - Is there any truth in this?
And other than taking the car to the Manufacturer, How would I go about tracing where in the car my tracker device has been fitted?
Username: Gonzo12
New York, Manhattan USA
Ideally, GPS Tracker would only work when in ignition and that's generally when you're on the move so I don't think battery drainage would be an issue.
Second, check your manual for hints but taking it to the dealer to know your GPS device location is the best bet.
Username: Johnvella
New York City, New York United States
Post Number: 7
wow, its really helpful post
Username: Turnerdaniel770
Post Number: 12
Agree with you. This nice and helpful post for GPS device .
Username: Zara1200
This is damage for the battery of the car. You should change it. http://www.gari.pk/
Username: Azel_29
fixing your gps will cost you more effort and and there is no assurance that it will work right?
Username: Kingsbuying
yeah, I have the same confusion with Gonzo12. Shouldn't it only when you driving your car and started your GPS that it will consume battery?
Username: Brianmoore
it should only be on while you are driving , otherwise it will consume all your battery . The battery keeps charging it self while you are driving.
Need to Register?
Forgot Password?
Enable HTML code in message
