CD stuck in disc player in my 2005 VW Beetle after battery was replaced!
Username: Bullymama67
Hi. We just took our 2005 VW Beetle in for some repair and the battery was gone. The mechanic replaced the battery and ever since, we cannot get the disc out of our player (single cd/mp3 player.)
It shows "no disc" on the screen but will not let you put another disc in because one is stuck in there. Also will not let you eject.
HELP!
T
Username: Billybobjoesmithjr_th_3ed
South, TX US
Post Number: 122
there should be a small reset button on the radio faceplate use something small like a toothpick and press it in...then count to 3 ...release the button and it should be good as new :-)
Username: Domenico
Glendale, AZ USA
Post Number: 145
x2
Username: Arm9t
I am having the same problem with my 2004 VW Beetle (it's the special edition Satellite Beetle). I've taken a look at the control panel and can't find the reset button that's been mentioned. Could someone be more specific as to where it is?
Username: Texancobra
reset button on a 2005 beetle cd changer? If so, where is it located exactly? Unable to see one..
Username: Joyceshang
Seems many guys have the questions. Thanks for the methods
Username: Nency
Post Number: 36
William is right.. So many people eject their CDs like this.. The most common solution is going to some cd player shop or car audio equipment's shop and tell them to eject CD from the player..
Username: Robyndee
Hi,
I have a VW Beetle 2005, i seem to have a CD stuck in my main CD player?
I have tried pressing the eject button, the cd player makes a loud clicking noise , like the cd is stuck on something?
I can not find the reset button?
The message on the CD player is CD ERROR??
What can i do? HELP!!
Thanks
Robyn
Username: Aleenajoe
Nottingham , Nottinghamshire UK
Woo! it is great ....
Need to Register?
Forgot Password?
Enable HTML code in message
