Please help
Username: Renult99
Battery died ( need code...
Module number: 22DC449/62L
Product number: FD0898284181967
barcode, I think: 7700426414F825
Anyone who can help please
Username: Hay88
PortsmouthUk
Post Number: 2944
Renult99
code 2718 you must hold at the end to store the code.
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
Username: Renult99
Much appreciated, thanks alot
Need to Register?
Forgot Password?
Enable HTML code in message
