Can anyone help me please - car battery died and now radio won't work. Radio is for 2003 Renault Scenic (Phillips) Model 22DC278/62P Barcode is 8200152346TZ579
Joenathan your code 0483 you MUST hold at the end to store the code. Code Entry as Follows:
Switch Radio On - Display Shows " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
Hello, I disconnected my radio today and now it ask for a code. Can anyone help me :-) Radio is for 2007 Renault Scenic (Phillips) Model no. RENRDW132-10 Barcode is 8200300859TA326 Car no. VF1JMRGL636243453 Thanks in advance for any help you can offer, Kind regards, Jan
your code 0130 you must hold at the end to store the code. Code Entry as Follows:
Switch Radio On - Display Shows " CODE " Then " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
