2009 Ford Explorer Navigation
Username: Rcarteraz07
Frederick, MD
I am looking for the Navigation unit that they use in the 2009 Ford Explorer or one that will work but looks like Factory and uses all the features of my explorer...i.e. steering controls, line in, reverse sensing and I would also like to get bluetooth to be incorporated too.
Username: Susiehe
Post Number: 16
Maybe you could have a look at ZorroGPS to see if it meets your need. It is specialized in GPS navigation.
Username: Limlin
Yes, ZorroGPS has a free trial about one week. You can try it first and then decide whether it's fit for you or not.
Need to Register?
Forgot Password?
Enable HTML code in message
