How to build a Sub Box
Username: 71_chevelle
Post Number: 74
I was wondering what gauge wire do i use to wire my two subs together.
and what is the item called that once the box is built you plug the wires to on the out side of the box and where could i find one.
i'm trying to build my own sub box
Username: Van_man
Boston South, MA
Post Number: 4209
12 quage is the norm for wires. and I think you mean a terminal cup.
Radio shack is good for them, or ebay.
some ppl just drill a small hole and run it direct, or use bolts as teminals.
One dude just runs it out the port.
Post Number: 75
oh hahaha ok ok yeah i believe thats what i'm looking for
thank you!
and will it matter if i cut a hole in the side of the box? like affect the air tight of the box?
Username: Van_man
Boston South, MA
Post Number: 4211
yes, if you choose to drill a hole and run the wires thru it, Tie a loop in the wire on both sides so it cant be pulled or pushed from the box, and put a few dabs of caulk around it to keep it air tight.
A pic is worth 1000 posts!!
Post Number: 17860
Seal it with silicone.
Best connection is direct. Drill the hole, run the wire. A good tip is to tie a knot in the wire right at where it will pull through the box. Pull it tight and silicone it to the inside of the box.
I've always loved terminal cups/banana clips myself.
I love being lazy.
Long ago, out of shear curiousity I once tried using a......awwww fug, forget it lol.
Post Number: 17861
Marc is a faster typer than me.
Post Number: 76
ok i think i'm going to use a terminal cup and the 12 ga wire for my subs =]
thank you Marc!!
Username: Van_man
Boston South, MA
Post Number: 4213
np.
you got a 71 chevelle?
and Lol Paul.
Post Number: 77
yes i do Marc
that's the project i've been working on for the past 3 years and i've just recently got it on the road bout 4 months ago. put a 454 in it, gas mileage sucks!! and now i'm just getting around to putting a sound system in it. still a little new to it all but i understand quite a bit thanks to the people here. they are very friendly and helpful! =]
Post Number: 17863
Post Number: 78
Paul you have a 71 chevelle as well?
Post Number: 17864
I wish.
Post Number: 79
oh i see i'll have to throw some pics up here with my progress on building out my trunk and installing the speakers.
will probably have plenty more questions lol but thats why i have you guys...thank you
Username: Van_man
Boston South, MA
Post Number: 4215
wicked. thats my fav year chevelle. Was at a car show last night, there was a few there. Just a great car.
GL.
Username: Surferdude9371
Im BTL Bumpin
Post Number: 1149
looking at your user name 71 chevelle if thats what ur installing this in i would have it done professionally fiberglassed in and all you dont wanna have an install that looks like crap in a nice ride like that (not incenuating youd do a bad job but u know what i mean)
Post Number: 80
Its mine too!!! I like the 71 tail lights better than the 69.
The car isn't complete though. It still has many more years of work on it and when i aquire the cash needed haha!
i would like to put it in the Pismo Car show out on the West Coast. It always has many many chevelles with a ton of ideas for your own.
Thank you Marc
Post Number: 81
Yeah i know what you mean P.rick
and i'm still debating on doing it myself or having it professionally done.
If i did it myself i would just make the boxes out of 3/4" MDS wood and carpet it along with the rest of the trunk but if i get it professionally done they want to do the same thing and charge me $500 for the entire trunk. Its worth it for a nice car to look good in but i some what feel i can do it myself and make it close to professional looking. But like i said i'm still deciding on what to do
