4inch speaker
Username: Ashokdurai
Chennai, TN India
Hi,
i am in look out for some high end speaker probably component package.
but the restiction is that.. my car which is Fiat Uno has company provided housing both in front and rear which allows only 4 inch / 10cm.
and i want it especially placed inside tht.
can any one suggest anything max in an 4inch system?
Username: Exige
Post Number: 67
if you throw a sub in the back, you'll be fine.
CDT's ES-42i component set is one high-end option that will fit your 4" requirements. and don't worry, at many places you'll see a retail of $680. it can be found for much lower.
Username: Exige
Post Number: 68
here's a link for you: http://www.buycdt.com/es42i.htm
Username: Mrsq
California
Post Number: 173
now is this cdt thing really worth for 600 bucks, man i mean how good is it for that price, because really you can get a ts-c720prs component set and way cheaper but awesome sq
Username: Nd4spd18
Northwest PA
Post Number: 5730
Thats retail price you can get them for a lot less
Username: Drant19
DUB-C, TX
Post Number: 276
ts-c720prs are a 6.5"speaker...
i dont know why that was brought up
Username: Mrsq
California
Post Number: 174
oh didnt read it right, he wants only 4inch, try QSD210 4inch comps by MBquart
Username: Exige
Post Number: 69
there's a reason i said that it can be found for much lower than retail. how bout lets not bash the price, and instead read the posts, mmk?
Chennai, TN India
thks a lot frnds.. i will chk it out.
Chennai, TN India
how far focal is good to CDT?
Username: Exige
Post Number: 73
please reference another current thread here in the forum called Focal vs. CDT. Focal and CDT are both great, high-end brands...but they are different in sound. Check out that thread for more info.
Chennai, TN India
thks.. i will chk but can some one say the diff of wht is component system and co-axial system? :-( sry if tht was an too lame question
Username: Nd4spd18
Northwest PA
Post Number: 5838
I believe thats explained in the other thread also
Username: Exige
Post Number: 83
yep both are explained....please reference the thread: https://www.ecoustics.com/electronics/forum/car-audio/438908.html
