Looking for a FORD NAVIGATION SYS for 2007 Expedition
Username: Peterny1
Melville, NY
Hi All,
I am looking for an Ford Navigation Unit that will fit into my 2007 Expitition. Anyone know of any used or new for sale? I looked on E-Bay and No luck? Please Advise thanks
Peter
Username: Peterny1
NY
OPPS "Expedition"
Username: Wmckay
Fayetteville, NC US
Sir, I have a new one for sale, please contact me @ wmckay@nc.rr.com
Username: Peterny1
NY
Hi Peter here. I just sent you an e-mail to your regular e-mail and also reaching out to you here.
Please feel free to call me 484-553-6580 or 631-421-1592
Thanks Peter
Username: Wmckay
Fayetteville, NC US
Post Number: 11
I have another Nav Radio for an Expedition
Username: Beav626
Okc, Ok USA
Post Number: 11
I have a new Nav system from the factory Nav unit out of a 2003 Navigator...
but for what I would sell it for you could buy something aftermarket that you might enjoy better.
Username: Anapier
William,
I recently bought a ford navigation via ebay, and had it programmed thru ARC. I added the factory Bluetooth (mobile ease) and HD radio(peripheral oem ford), and neither one of the add ons are working properly. The GPS has a GPS icon on the screen with a red line through it I'm assuming it is not active because the icon.
So here are my specific questions:
The HD radio does not work at all. Any quick fixes?
Should I put the Mobile ease or the HD radio wiring harness last?
Everything seems to work on the Mobile ease but the caller volume. I can use the voice recognition w/no problem, but I can't hear incoming calls, and they can't hear me.
Can you help with any of this?
Thanks,
Need to Register?
Forgot Password?
Enable HTML code in message
