Ideas for amps for fully loaded 18" BTL.
Username: Lowgan
Post Number: 23
I just want to be absolutly certain about an amp before i buy it, there kinda expensive.
Username: Bump05
CashMoney, 15 Hd3 USA
Post Number: 1036
i can get you a memphis 4kw perfect for that sub depending on ur coils... for 900 which is a sick deal cause there brand new for 1600
Username: Lowgan
Post Number: 24
i need one that will run dual 1 Ohm voice coils.
Username: Jkidder
Spring hill, Florida Usa
Post Number: 419
if u have the money buy a kicker kx2500!
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4346
something putting more than 2k for sure.
Username: 420alldaylong
Post Number: 1318
Budget?
Username: Rovin
My 1 12 Atom...
Post Number: 11131
from what i read reg BTL takes 2000\2500 with ease so a modded 1 should feel good with 3000-4000wrms
go ebay ......
Username: Killswitchjd
Post Number: 370
two amps that put out 2000x1 at 1 ohm, maybe 2 orion 2500d's to go big
Username: Bump05
Post Number: 1037
I can get you brand new kicker amps memphis amps digital design amps let me know eastbayafi05@msn.com
Post Number: 1322
AutoTek MM4000.1D
Username: Lowgan
Post Number: 26
my budget would be about 800 dollars.
Username: Th3pwn3r
Post Number:...
Post Number: 1705
Either save up another 100 for that memphis or buy a used amp.
Username: Nd4spd18
Southeast PA
Post Number: 1206
There is a guy selling an american bass VFL 200.1 for $515 on caraudio.com:
http://www.caraudio.com/forum/showthread.php?t=218147&page=3
That amp will do 3000 watts. He had two and I bought one
