Pick which speaker is best for my 55 RMS amp
Username: Camaro155mph
Post Number: 359
Below is a list of speakers, followed by wattage and the price.
Pick which speaker is best for my 55 RMS amp.
Please factor in price when choosing.
They are sorted Lowest to Highest in Price.
Infinity Reference 6012i Coaxial 60 RMS $70
Phoenix Gold ZR6.5 Component 70 RMS $90
Alpine Type S Component 50 RMS $100
Alpine Type R Coaxial 50 RMS $103
Infinity Kappa 62.7i Coaxial 75 RMS $104
MB Quart DSE-216 Component 120 RMS* $108
Diamond Audio CM361 Component 60 RMS $120
Alpine Type R Component 70 RMS $140
Infinity Kappa 60.7CS Component 90 RMS $165
CDT Audio CL6B Braxial Component 90 RMS** ?
*Is that right? It seems way to high.
** Do Not Know the Price
Username: Basshead86
Google is your Friend, FL
Post Number: 3680
DLS Reference Ps6:-):-):-)
they sound amazing:-)
Username: Panocha
Post Number: 197
he said out of those in the list.....out of those you mentiomed i would go with the infinities or the cdt,s
Username: Adddisorder
West palm, Florida
Post Number: 324
probly the type s components or type r coax considering your power situation
Username: Killswitchjd
Post Number: 126
get the new kappas- there two ohms and then you will get twice the power from your amp, and you will give it just about the right ammount of power.
Username: Tjmutlow
Post Number: 2243
i have the JL xr coax for 150 delivered.
Username: Alteraudiousa
Concord
Post Number: 894
i would go for the CL-6's but not the braxial mount unless you know you have about 1.5in clearance in front of the speaker or they are surface mounted. I can get you a price on them if you email me at sales@alteraudiousa.com
Username: Johammbass
Cork, Cork Ireland
Post Number: 244
Don't go with a coax,
And none of the above:-)
Go with DLS
Post Number: 362
How would I wired them to make the amp give out two ohms? Would I just connect the wires as normal and the amp would send put out the 2 ohm wattage (65 RMS) to the infinitys? Would i still be able to run my other speakers at 4 ohms?
What I want to do is just unscrew the mounting screws of the old speakers, disconnect the 2 wires in back, attach them to the crossovers, then the wires from the Crossovers to the components, and mount the speakers. I don't want to have to rewire from the amp to the door panel, because thats a B*tch.
