Circuit Breakers vs Regular Fuses
Username: Jprix82
Post Number: 350
What are the pros and cons of each of these setups?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11373
fuses are more finely adjustable, in that you can get more minutely stepped variances in ratings, and fast reacting or slow blow, etc..
a ckt breaker doesn't require anything to be replaced if it's tripped, and can be had in an auto-reset moel. you generally use a breaker for high current lines like by the battery, and fuses for each amp to protect the electronics.
Username: Jprix82
Post Number: 395
so circuit breakers wouldnt be a safe thing to use with a amp?
Username: B101
Queen City, NC USA
Post Number: 1940
BOTH WILL WORK, thats what he is saying! Pick 1!
Username: Jprix82
Post Number: 398
Oh ok^^,IMO circuit breakers could save you some money in the long run but if you change setups your circuit breaker might not match up with the amps of your new setup so you will have to buy another one,where fuses you can put any size fuse to match up with your setup.So ill prolly be going with fuses.
Username: B101
Queen City, NC USA
Post Number: 1944
fuses are cheap anyway... 2-5$ for a ANL type fuse..
Username: Jprix82
Post Number: 408
"2-5$ for a ANL type fuse"..........Where at??
Username: B101
Queen City, NC USA
Post Number: 1986
any car audio store.. lol / I payed 5 bucks for a 200a fuses, all day... U can also check a boat store, they carry alot of ANL fuses, all types! ranging up to 500a!!!!!
Username: Jprix82
Post Number: 421
A local audio shop by me trys to charge $10ea for ANLs,guess im going to have to check out a boating supple store.
