New alt. extra battery? what do i need
Username: Seanos
Sterling, Va
I have a 2000 VW Jetta i'm planning on putting a 1200 watt rms amp powering a solobaric L7 and a 400 watt rms amp powering 4 mid range speakers, a 30 band equalizer, and a alpine dvd player with a motorized screen and an extra 7 inch lcd in the trunk lid, now i'm assuming my stock alt and battery will not be able to power all this, or am i wrong? what do i need to get in order for everything to run smoothly?
thanks
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1370
your gonna need about a 200 amp alternator for sure. might want to look into an Optime Yellow TOp too. always a good idea to change battery out as well.
check out:
www.excessiveamperage.com
or
Irragi Alternators on ebay, Seller name - Trafficjamz
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11372
http://www.bcae1.com/capacitr.htm
http://www.glasswolf.net/caraudio/capacitors.html
http://www.glasswolf.net/caraudio/charging.html
http://www.betteraudio.com/geolemon/newmain/battcapalt/
http://www.bcae1.com/charging.htm
http://www.bcae1.com/chargin2.htm
http://www.glasswolf.netS/caraudio/batteries.html
http://www.the12volt.com/info/recwirsz.asp
