Orion wcc 5000d
Username: Steven132221
Post Number: 57
is this amp 1 ohm stable??? i want to get 2 15" L7's that are 2 ohm so i can wire it to 1 ohm.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11280
www.orioncaraudio.com
you can look up the specs.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 5915
LOL^^^^well ok then
Username: Tjmutlow
Post Number: 1518
you need dual 4ohm subs to run 2 subs
Post Number: 58
why do i need 4 ohm subs? why cant i have 2 ohm subs and run them at 1 ohm with this amp and just turn the amp down some?
Username: Tjmutlow
Post Number: 1527
you can not run 2 dual 2 subs to a 1ohm load it can go 1/2 or 2ohm load only
Post Number: 60
why? so i could run at 1/2 ohm though?
Username: B101
Queen City, NC USA
Post Number: 1447
why, becuase thats how resistance work! google ohms law!
ty mutlow is correct, either .5 or 2ohms.
now that been said, the wccd5000 is the orion2500d; these amps are .5ohms stable for daily; I still dont recomend you hookin it up at .5, the amp will put out about 2800rms
Username: Tjmutlow
Post Number: 1533
the amp is not recommended at .5 load., just get the dual 4 subs and solve that problem.
Username: B101
Queen City, NC USA
Post Number: 1467
they dont say it is, but its proven to be (tested) daily! @ .5ohms.. without even getting warm! its a very good amp. it acutally has a sweetspot at .34ohms for burps... but for starters I would do what its recomended..
that amp is rated @ 1ohm. so he needs dual 4ohm vcs..
Username: Tjmutlow
Post Number: 1534
Just another tidbit, that amp needs power, I ran it on 2 orion P15s, the amp will cut off unless it is powered correctly.
Username: B101
Queen City, NC USA
Post Number: 1475
yea, the amp can pull over 200 amps of current at full tilt!!
Username: Usask8er1
Appleton, Wisconsin USA
Post Number: 58
While where on the subject I have a wcc-D5000 and a orion h2 15.2 I just got in, how much power can I run to the sub without having to worry about it burning up the voice coils like my power acoustik and audiobahn subs did?
Username: B101
Queen City, NC USA
Post Number: 1502
how much power??
get 2 of the wccd5000s and watch the gain! but I know people who gave them 4000rms safely! dont worry about blowing with that amp, just set the gains high, without clipping.. and enjoy your back been blowed out!
