Alternator Positive to Battery Positive Post / Inline fuse needed ?
Username: Suleman36
Maryland U.S.A.
Post Number: 3207
Im going to be getting a HO alternator with Excessive Amperage and i have a 98 Toyota Camry.
When i run my big 3 should i use 4 gauge and if so do i need to fuse the line for alterator positive to battery positive or not ? Im confused with this part.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11292
4AWG is fine.
Fuse isn't required, but it doesn't hurt just to protect the alternator.
for 4AWG wire, I'd use a 125-150A fuse there.. rated to protect the wire pretty much in case of a dead short to prevent engine compartment fires.
Username: Suleman36
Maryland U.S.A.
Post Number: 3210
Is it ok to still use a 150ANL fuse if its a 180-200A HO alternator ?
Also do i bypass the fuse box when im making this connection.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11296
yes the fusebox is useless at that point.
for a 200A alternator, you want 0AWG wire, not 4AWG, and for 1/0 AWG wire, use a 225A fuse.
use 1/0 for the big three.
you can use 4AWG for the battery to amplifier(s) if you're not going to draw more current than the 4AWG can handle with your amps. remember current capacity depends on two factors
gauge, and length of wire
Username: Suleman36
Maryland U.S.A.
Post Number: 3226
Ok can i use a 200A ANL fuse from battery positive to alternator positive instead of 225 since www.knukonceptz.com only has 150,200,250
Like this one http://www.knukonceptz.com/productDetail.cfm?prodID=FH-20
The alternator hes building me will be just shy of 200A total.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11328
yeah that'd work just fine
Username: Suleman36
Maryland U.S.A.
Post Number: 3229
ok thanks, do i want have the inline fuse a certain amount of inches to the alternator or battery in this case ?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11334
right about the middle is fine :-)
