Can one of you guys Glasswolf, Jexx, or optidriven help me please
Username: Bradgman
GAlVeStoN, Tx Usa
Post Number: 91
I sent this in another form, but just in case you guys dont receive it or need a better diagram here it is again. Thanks a lot
Brad
application/mswordUpload
system pic drawing.doc (47.6 k)
Username: Infinity_addict
Santa Rosa, California USA
Post Number: 239
yah, all looks good. the only thing just a lil different is that the speaker wire coming from yer 2ch amp will hit the crossovers first, then speaker wires from the crossovers will split off to yer tweeter and speaker.
but yah, everything else is check. that cap won't help anything btw.
Post Number: 240
scratch that. yer gunna need 2 seperate 4guage lines for each amp. the single 4guage that splits at the cap won't be able to handle the current demanded.
Username: Bradgman
GAlVeStoN, Tx Usa
Post Number: 94
The crossover is just a little box on the tweeter about the size of an ice cube, should i still do it? The kappa will get enough power after the crossover?
Thanks for the help
Post Number: 241
it may not be a crossover. crossovers are little boxes, yes. generally they have two wires entering one side, and 4 wires exiting the opposite side. is that what is on yer tweet?
