Big Three
Andrew Carter
Is there a place to go where they will cut the wire and crimp it for you....i dont have any tools to do it
Username: Pelona
Post Number: 197
use your teeth
Los Angeles, CA USA
Post Number: 2103
lol that will hurt.
Username: Pelona
Post Number: 201
thats what i do
Los Angeles, CA USA
Post Number: 2106
do you strip the wire with your teeth or crimp with your teeth?
Username: Fandim
Reno, Nevada United State...
Post Number: 632
Heh.. Crimping wire can be tough, especially with those gold 0 gauge ring terminals. I use a big pair of plumbers channel locks, since I dont have a vise.. You can get'm cheaply at Walmart.
Curious, has anyone found any real advantage to soldering ring terminals are they're crimped? Is it really any sturdier at all, or help with conductivity?? Also, how do the ring terminals (the ones with just an input, but not a hole all the way through, they come down at a slant and close off at the top) that are solder only work? Are they very secure?? Just curious about these things..
Seth
Username: Pelona
Post Number: 208
i only strip my speaker wires with my teeth. Like 14guage and up.
I tried it with a 0guage power wire but it was impossible! LOL
Los Angeles, CA USA
Post Number: 2107
lol hahaha you actually tried it? i gotta confess. i tried that too and you're right it is impossible.
Username: Rovin
Trinidad & T...
Post Number: 5098
i use my 6" bench vice ! .........
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1922
to strip 1/0ga wire, i use a pocket knife. and to crimp to terminals, i use a vice or a shop hammer.
Username: Pelona
Post Number: 214
i just get a knife and cut around it. then you just slide it off.
Username: Pelona
Post Number: 215
To crimp i use a rock. Now thats gangsta!
Los Angeles, CA USA
Post Number: 2108
hey i gotta question. i was thinking about repositioning my amps and my 1/0 gauge cable will be too short now. is there anything that extends the cables or do i have to get a new cable and start from the battery.
Username: Pelona
Post Number: 216
i would get a new cable cause i think you lose voltage if you add another little piece.
but itll cost some $$$
Los Angeles, CA USA
Post Number: 2109
sh!t i was afraid of that. i'll just leave my amps where they are.
Username: Fandim
Post Number: 637
No, you can use a coupler (with two 0 gauge inputs) that looks like a chineese finger trap, and comes with a protective sleeve) that shouldnt cause any voltage loss.
Los Angeles, CA USA
Post Number: 2113
okay seth i got another one for you. i am thinking of adding a batcap. at the moment i have a 1/0 gauge cable splitting into 2 4 gauge cables with a fuse distribution block. i want to add a batcap. my question is do i get rid of the 300a that is by the battery and just go straight cable it to the batcap or do i leave the 300a fuse block by the car battery.
Username: Fandim
Post Number: 645
No, each one should be fused. Leaving a wire that carries so much current unfused could lead to a serious disaster. Fuse both the first battery, AND the second battery.
Better safe than sorry.
Username: Jbump
Nebraska City, Nebraska USA
Post Number: 133
I just use a hammer to crimp my eyelets, and my sharp utility knife i made out of a heavy butterknife, actually holds a good edge for doing stripping jobs...
