Need schematics....
i need the wiring diagram for a chevy cobalt 2005 ... wondering if n e one knows the:
- color of the speaker & power wires
- where the accessory wire is (someone mentioned fuse box...but which wire is that!)
Username: Illuminator
Post Number: 2056
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red |+ |ignition harness *1 |
| STARTER|yellow |+ |ignition harness *1 |
| IGNITION|pink |+ |ignition harness *1 |
| SECOND IGNITION|dk. green |+ |ignition harness *1 |
| ACCESSORY|orange |+ |ignition harness *1 |
| SECOND ACCESSORY|brown |+ |ignition harness *1 |
| POWER LOCK|white |- |drivers kick panel in |
| POWER UNLOCK|same wire |*2 |a black plug |
| LOCK MOTOR|gray | |drivers kick panel |
| UNLOCK MOTOR|tan | |drivers kick panel |
| DISARM DEFEAT|tan | |passenger kick panel |
| PARKING LIGHTS +|brown | |passenger kick or column |
| PARKING LIGHTS -| | | |
| HEADLIGHTS|dk. blue & pink |*3 |steering column |
| DOOR TRIGGER|*4 |- |*4 |
| DOME SUPERVISION|white |- |dash light or column |
| TRUNK/HATCH PIN|orange/black |- |trunk light |
|TRNK/HTCH RELEASE|black/white |+ |drivers kick panel |
| TACHOMETER|purple/white | |ignition coil or ECM *5 |
| SPEED SENSE|dk.green/white | |ECM *5 |
| BRAKE WIRE|lt. blue |+ |at the switch |
| HORN TRIGGER|black |- |steering column |
| WIPERS|dk. grn & purple |+ |steering column |
| LF WINDOW UP/DN|dk. blue - gray |A |drivers door switch |
| RF WINDOW UP/DN|lt. blue - tan |A |drivers door switch or kick |
| LR WINDOW UP/DN|dk. green - pur/wht |A |drivers door switch or kick |
| RR WINDOW UP/DN|lt. green - purple |A |drivers door switch or kick |
| SUN RF OPN/CLOSE|blue - green |A |sunroof motor |
| SUN ROOF LIMIT| | | |
| RADIO 12V|orange |+ |at radio |
| RADIO GROUND| | | |
| RADIO SWITCH|yellow |+ |at radio |
| RADIO ILLUMINATE| | | |
| POWER ANTENNA|dk. green | |at radio |
| LF SPEAKER|tan - gray | |at radio or LF speaker |
| RF SPEAKER|lt. grn - dk. grn | |at radio or RF speaker |
| LR SPEAKER|brown - yellow | |at radio or LR speaker |
| RR SPEAKER|dk. blu - lt. blu | |at radio or RR speaker |
Check to make sure it doesn't require any additional adaptors to still function with your system. Also note that this is to be used as a guide and I'm not guaranteeing the wiring colors to be perfectly matched.
THANK U JEXX ... if anyone knows if a wire is a diff. color..please post
Username: One4themoney
I need to connect a ACCESSORY wire for my head unit ... where does it get connected or wired to??
for a chevy cobalt...there are 3 diff. color grn wires coming from the stock radio harness ... which is which??
so no one has n e clue what the 3 diff grren wires are for the radio ... light green, mid green & dark green ...2 must be speakers but whats the other???
I need the wiring schematics for the kenwood excelon. How to get power to the brain wiring?
Post Number: 2114
You'll have to start a new thread, please.
Is that wiring schematic good for remote starting, I have been looking all over for the window type/colors for a roll up/down module. I have another wiring lay-out (from design-tech) but the wiring is way different from your schematic (ignition what-not wise). And would this work for both a 2005 cobalt as well as a cobalt ss.
