Newbie Wiring Question
kungpowchciken
This isnt something that i am planning on doing, i am just wondering it. How do you wire multiple amps to a single woofer.
Username: Quickshot
Charlotte, North Carolina U.S.
Post Number: 160
put one amplifier per voice coil...although thats not reccomended because even if an amp is the same model as the other one they always put out slightly different wattage so the uneven power will eventually hurt the sub
