Using a distribution block to ground
Kyle Allen
Do any of you guys use a distribution block to ground your system as well as feed it power? My brother told me to ground my amps through a distribution block to eliminate having several holes in my vehicle from grounding. Also, what gauge wire would you use to do this. Let me know what you think. Thanks,
kyle
Username: Carguy
Post Number: 3251
You can use 4gauge or lower, depending on your power requirement.
I use d block for my pos and ground.
Username: Suleman36
Post Number: 1502
Yeah kyle, i am gonna be using a distribution block for my power and ground also. My main lead from the battery is 1/0 so im gonna do 1/0 for my ground also. Just one hole is good.
Username: Msully701
Stratford, Connecticut US
Post Number: 171
yeah I used d blocks for power and ground had 1/0 guage in and 4 guage out on it all it makes it easyre
Username: Brownnugen
How would it work if you wanted to use a fused distribution block as a grounding block? I already have 2 fused distribution blocks that I purchased from KnuKonceptz so I would like to use what I already have. The blocks can be seen here: http://www.knukonceptz.com/pro...-3448
Would any size fuse work? Somebody mentioned a bridge, or something, but I don't know what that is. Thanks for the help.
