Problems With PIONEER DEH - P7500mp
Username: Toycar
LjubljanaSlovenia
I have a 2 years old headunit PIONEER DEH-P7500MP that worked just as it supposed to. Recently it started loosing power during listening CD`s. At first It started when i accelerated or drove off and on turns. So i took a close look to the wireng. I have foud out that there is nothing wrong with wires. Just the other day i have noticed that if i have the CD disc in the unit and listen to the radio the same thing happens over and over again it looses power just like i woud took the clams off the battery. And than back on ( DEMO STARTS and all the settings are lost ). So i took the CD disc out of the unit and the damn thing ( radio reciever) works without a problem. Does anyone know what could be wrong? I have disconected the sub too and still the same thing.
Pls help me out.
This is the second Pioneer Cd-reciever that started to fail after 2 years. the first one was the DEH-5100 where the display froze or just lost the power (music still playin but no lights on display At the repair shop they sad that there is no problem with the headunit.. :unsure: :mad:
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 168
Have you checked the ignition wire?
Username: Toycar
LjubljanaSlovenia
First thx 4 reply!
I have bypassed it . i connected the ignition straight to main wire. Still the same :-( .
Username: Toycar
LjubljanaSlovenia
Is it possible that my car battery is worn out. Car starts but it wont last a 15 min with lights on without car runnin? so when i drive and the motor vent starts it takes all the power and resets the radio?
Just thinkin
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 182
I would look at your fuses first(since they are cheaper) then the alternator. Once you start your car, all the power comes from the alternator, so it sounds like your alt might be on the outs.
Username: Toycar
LjubljanaSlovenia
ok Today i have put the front panel on and left the CD disc in the unit. The unit was turned off and he lost power and restarted than i left the unit off and took the disc out . The unit was off. and it didnt came on.( I was driving arround )
So Next thing to try. If the car is not running the radio will get only the power from the battery right?
Ok i will try everything with my car not runnin. I will let u know the resoult.
THX
Username: Toycar
LjubljanaSlovenia
still the same. I took it to the repair shop. Will let u know. :i
Username: Illuminator
Post Number: 61
That's one sweet paint job on that car...
Username: Toycar
LjubljanaSlovenia
Post Number: 7
Ok The problem with DEH p7500mp was that the power unit and its connection in the head Unit itself went to the hell. It costed me 43$. It works GREAT again.
Thx 4 all the help.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 302
Glad to hear it.
Did someone say bling bling?
Thats awesome.
