1994 ford explorer speaker wiring
michoil
Does anybody know the color codes for the speaker hook ups?.. As well as the silver wire, does that need to be connected to anything?
Username: Marley289
Post Number: 157
well for the speaker wires, you can check those by either taking out the speakers and checking, or you can take a DMM and test them out so that you dont get the power wires mixed up with speaker wires.
