Anonymous | i work at a place that gives me very good deals on kicker and infinity, so i can pretty much get 2 of their top of the line for under $300. The question is, which is better, i listen to mainly rock, some getting pretty heavy, and rarely any rap. Kicker s12X or infinity Kappa Perfect12DVQ? |
Silver Member Username: Basshead86Ocala, FL USA Post Number: 457 Registered: Aug-05 | get the infinity's |
Silver Member Username: CenusHicksville, Ohio Usa Post Number: 433 Registered: Jan-05 | what kicker sub is that, im thinking its the old round solo's but im not sure, but imo i would go kicker buts thats just because all the infinity stuff ive ever seen was complete junk. |
Silver Member Username: Basshead86Ocala, FL USA Post Number: 459 Registered: Aug-05 | i think this is the infinity subwoofer |
Silver Member Username: Basshead86Ocala, FL USA Post Number: 460 Registered: Aug-05 | 400 watts rms for $444.95 MSRP i'm not sure about the s12x though |
Silver Member Username: Basshead86Ocala, FL USA Post Number: 461 Registered: Aug-05 | is the s12x the Kicker 12" Solo-X? |
Silver Member Username: CenusHicksville, Ohio Usa Post Number: 434 Registered: Jan-05 | that much for that sub, damn i would get some re sub or somthing a lot better than that for that much money. |
Silver Member Username: Basshead86Ocala, FL USA Post Number: 463 Registered: Aug-05 | that's kinda the point i was gettin at! lol |
Silver Member Username: Basshead86Ocala, FL USA Post Number: 464 Registered: Aug-05 | for $255 more you could have 5x the power handling with a Treo SSX |
Silver Member Username: CenusHicksville, Ohio Usa Post Number: 435 Registered: Jan-05 | or get re se which is 600 watts rms i think, save some money to by a bigger amp and have a lot better system. |
Anonymous | i get each the infinitys and kicker at about 80% off, so i can have a 3 or 4 grand sytem for about 600 bucks |
Silver Member Username: CenusHicksville, Ohio Usa Post Number: 437 Registered: Jan-05 | well is that kicker the solo'x "the square design" or is it the old solo's that are round. |
Anonymous | brand new square ones, 2500 rms and 5000 peak watt |
Silver Member Username: Basshead86Ocala, FL USA Post Number: 466 Registered: Aug-05 | DO NOT BUY THEM!!!! |
Silver Member Username: Basshead86Ocala, FL USA Post Number: 467 Registered: Aug-05 | i'm not going to get into it, but if those are the only brands you can get for cheap, then go with the Infinity |
Silver Member Username: A3formePost Number: 355 Registered: Sep-04 | S12D is the old round Solo's. Someplace I saw online still has then "Brand New" |
Silver Member Username: QuickshotCharlotte, North Carolina U.S. Post Number: 137 Registered: Aug-05 | hey man all those infinity subs are pretty good and reliable....thye have some of the best SQ for the price and especially when you get them 80% you should buy them...only porblem is that their an SQ sub so they dont get too loud |
New member Username: Speedemon57Post Number: 1 Registered: Aug-05 | on their website it says the infinity kappa perfect12DVQ reach 92db and on the kicker website says the solox s12x reaches only 87.7, wouldnt that make the infinitys louder the manufacturer websites for the subs are http://www.kicker.com/05/05kicker.html click subwoofers, solo x, specs, then s12x http://www.infinitysystems.com/caraudio/product.aspx?ProdId='KAPPA+PERFECT12DVQ'&Ser=KPE&Cat=SUB |
Silver Member Username: Zero43Kyle, TX USA Post Number: 118 Registered: May-05 | thats the sensitivity not spl their talking about All that rating is is an efficiency rating |
Bronze Member Username: MrmbqPortland, OR USA Post Number: 12 Registered: Aug-05 | That Infinity Kappa Perfect subwoofer is a great sounding speaker...especially if you listen to rock. If sound quality is what you want, the Kappa Perfect is the way to go...just make sure to get the right kind of enclosure and the correct amount of power. |
Silver Member Username: Riebread77Post Number: 534 Registered: Jun-05 | dude you work for circuit city right? yea my boy is getting me the discount off of the infinity perfect components...the deals are sick...if you get the infinity subwoofers...you have to get 2-3 subwoofer...if you get the kicker solo x...get one...honestly if you get a discount on kicker stuff...I'd get 1 10" kicker solox and put an sx1250.1 on each voice coil..that'll pound like no tomorrow...the infinity subs have good SQ but don't get loud at all..it'll require 3 subs to get pretty loud...1 10" would be sufficient from the solo x and probably pound as hard as 3 infinity 12s...getting the 10" solox will help with SQ too as it'll respond faster...many people have infinity subs...how people do you know with a solox setup???...i'd go SOLOX |
Silver Member Username: Basshead86Ocala, FL USA Post Number: 479 Registered: Aug-05 | No one can say it better that GlassWolf so
Silver Member Username: Basshead86Ocala, FL USA Post Number: 480 Registered: Aug-05 | forgot the first part
Silver Member Username: Riebread77Post Number: 537 Registered: Jun-05 | what you are say is that the infinity will be louder than the kicker solo x which is obviously wrong... You have to be careful when looking at reference efficiency (sensitivity). You can make a speaker really efficient by designing the voice coil to fit entirely in the magnetic gap. This would likely yield a sensitivity of 104 or so. This speaker may work very well if powered by a low powered amplifier because of the high efficiency but would not be able to produce high SPL at low frequencies because it would have a very small xmax. Actually, if the voice coil length was the same as the height of the magnetic gap, it would have no (zero) xmax. |
Bronze Member Username: John8x12Post Number: 63 Registered: Aug-05 | I have Infinity Kappa Perfect 12"'s and I hit 150 db with awesome sound quality. Of course I have 8 of them with 3000 watts pushing them... |
Silver Member Username: Infinity_addictSanta Rosa, California USA Post Number: 106 Registered: Jul-05 | dang john, lotsa money! i have two 12DVQs in a sealed enclosure in a 4dr wagon powered by the REF1211a (round 400 RMS each, just what they need). i got friends that work at circuitcity... :-) anyways, they sound great and do get pretty loud, then again, i havent been metered, but round 40hz, it hz. (not unbearable but it'll make ya cringe) |
