Surround sound dilemma
Username: Grief
Post Number: 21
Hi! I don't know if this is the right place to post this, but anyway here it goes. I bought a pioneer vsx-520 receiver as part of home theatre kit, i can't begin where to tell where i went wrong with this receiver I've tryed everything auto-calibration, manual, different speakers, inverting the polarity in all the speakers , using a bookshelf as a center speaker but nothing I haven't been able to get the true cinematic feel from this home cinema. If someone is reading this thread and has experience with this receiver please post your settings or give advice, for I'm abou to give up on surround sound.
Username: Vm8444
TorontoCanada
Post Number: 405
Yes you sound like its over your head . Just hire a local Private installer for 2 hours maybe .$125 or so .
Let a Pro help in the long run its well worth it and highly enjoyable if setup right.
theaudioguy.ca
Username: Grief
Post Number: 22
Yes, that would be awesome the problem is I don't have the money to hire a professional, by the way my receiver works with the metric system would it help to set delays as per the formulas given on the net? for example 20 ms= 6 meters?
Username: Roseywat
The surround sound systems are best to be used as they tend to provide full entertainment at home and that too without any interference.http://www.mcintoshlabs.com/us/Products/pages/ProductDetails.aspx?CatId=Speakers &ProductId=HT30OW
Need to Register?
Forgot Password?
Enable HTML code in message
