Onkyo surround sound not working?
Username: Srigayaz
HI All,
My friend is having an onkyo surround sound system model number HT-SR600 (s) which is 2006 model (not sure when it is launched)
Wanted to know is worth of buying this model for Rs: 6,500/ and all speakers are working fine but the front speakers are producing less sound and its like tweeters sound, but they worked in the similar way when kept in rear speaker ports. I'm pretty sure this means it is speaker problem?\
One more thing is to listen good music need to keep the volume at 45 level or more.
I don't really know whether is it a good deal to buy this hometheatre Can you please help me out ?
Username: Captapple
Ma
I've got an Onkyo system (7-1) surround system and the
level I listen at is usually no more than 35..wife is a little hard
of hearing and the 45 level blows me away but she likes it..
as for the front speaker issue.. you can down load the users
manual from the (onkyo) web site...on my system you can
adjust the (decibel level) on each speaker...might just need
some tweeking the individual speaker adjustments..
I'd at least try that.
Need to Register?
Forgot Password?
Enable HTML code in message
