Best way to wire up the following ...
Username: Richardfenn
Hello forumers,
what's the best way to connect the following items up so they all can run through my Plus U2-1200 projector?
Virgin Media V+ box
Samsung DVD Player
Playstation 3
All the above have HDMI outs.
Could I run them all into a 4 in 2 out HDMI splitter then run one out to my tv and one out into an HD Fury and then from the Fury into the DVI or VGA connection on the PJ ?
(there is no HDMI input on the projector and it can't process an HDMI signal according to the manufacturers which is why I mention the HD Fury)
Would this be the best option or do you have any better or more practical ideas?
Many thanks if you can help
Need to Register?
Forgot Password?
Enable HTML code in message
