Setting up STR-DH520 w\h HTPC
Username: Hueristic
Hi, I'm trying to setup the DH520
http://store.sony.com/p/3D,-HD,-A-V,-Receiver/en/p/STRDH520#gallery
With my HTPC as the title states and I'm having a few issues that I'm hoping you guys can clear up for me. I Am using Svid from the 9800Gt to an Old CRT 36" Mitsubishi currently and a DVI to DB15 from the 7870XT to a 21" Hitachi CRT. Do to finances I'm not able to do any more upgrading at the moment.
HTPC/Gameing Rig:
Asrock Extreme 4
Saphire 7870XT
9800GT
AMD 1600T (unlocked960T)
8 G Gskill
1TB WD
PC & Cooling Silent 750
Components:
Phono : Sanyo TP 1020
Tape Deck : JVC TD-W118
1) What components to what inputs?
2) How do I setup the Surround without the auto calibration? Apparently the North American version of this amp does not support this feature for some Moronic reason.
Is there a way to use the auto calibration even though it's not supported. The Mic input is there so I am wondering if the hardware is there as well.
Sorry about the dumb questions but I haven't setup a audio system since stereo days let alone a AV one. In the future I will get a HDMI TV which I'm assuming will simplify the process.
Thanks alot.
Need to Register?
Forgot Password?
Enable HTML code in message
