Pioneer VSX-820 + Optima HD806
Username: Singhsane
NewYork USA
Post Number: 95
I have my projector hooked up to the Pioneer receiver using an HDMI port on the projector and the HDMI (Out) port on the receiver. Today i tried to hook up an FTA receiver to the Pioneer receiver using Composite cables. This didnt work. I tried several different composite ports on the receiver and i get no picture or audio. However, when i connect the FTA receiver directly to the projector via composite cable and change the output on the projector from HDMI to compostie it works fine. Anyone know if theres a setting i need to fix or is this simply because since my projector is hooked up the receiver via HDMI I can only use HDMI connections with the receiver??
Need to Register?
Forgot Password?
Enable HTML code in message
