Center Channel to match PSB Century 600i
Username: Klockner96
I'm finally going to upgrade from a stereo system to a surround system. My current speakers are PSB Century 600i. As a first step, i'm looking to add a center channel.
I understand that I should match my center channel as close as possible to the front speakers.
I'm not looking to spend much, perhaps $200, and used is fine too. Can anyone recommend a center channel that would match?
I see a few PSB center channels on eBay right now, but have no idea is they match. For example: PSB Image 9c; or Alpha C1.
Any help would be appreciated.
Username: Vm8444
TorontoCanada
Post Number: 360
sure psb image is still in the same family
should be fine on your budget.
theaudioguy.ca
Username: Mrd
2 re xxx 15s ,ae slot ported box ,marine battery, 0ga wiring, an memphis mojo 4000d asking 1400obo
Username: Superjazzyjames
Post Number: 616
Make sure ALL of your speakers have the same type of tweeter (cone, soft dome, hard dome, horn, dipole, etc). The tweeter is what determines a speaker's character. Different types of tweeters will not work together.
Need to Register?
Forgot Password?
Enable HTML code in message
