Panasonic SA-PT660 LCD Blank
Username: I_likes_da_bass
Bentonville, AR USA
Post Number: 364
This is a 5.1 5 disc DVD changer surround system. I went to power it off and I shocked it from my finger and after that the LCD display stopped working. I just figured it blew a fuse but I have taken it apart and can't find a fuse anywhere. Can anyone help me locate where the fuse would be if it has one, or tell me how to test the LCD display somehow to know if it is just completely fried? Thank you.
Username: Superjazzyjames
Post Number: 524
There probably is no fuse. The most cost effective thing to do: replace the player, then make sure you're static free when touching it.
Bentonville, AR USA
Post Number: 365
I was afraid of that. They aren't that expensive, but I hate to throw the whole mess out when the speakers and everything else still work just fine.
Post Number: 544
A static shock is approximately 3000 volts! You don't die or feel affects because the current is very low. However, electronics don't handle it well at all. Just the same, there should've been something preventing that shock from harming your system. A fuse probably wouldn't have helped here anyway. Too much current is what blows fuses, not too much voltage. It wouldn't have even noticed that static shock.
If you are interested in upgrading to something that will last longer, sound better, and not be so vulnerable to static shock, let me know what you'd be willing to spend and your room size and I can give you some suggestions.
Need to Register?
Forgot Password?
Enable HTML code in message
