Denon DHT391XP Reviews
Username: Crazylad
Denon DHT391XP is the entry level HTIB from Denon. I am inclined to buy this HTIB for the following reasons:
(i) It is Denon
(ii) Wooden speakers (all the 5 channels + subwoofer). Not all the entry level seem to have 'all' wooden speakers
(iii) 4 HDMI inputs and 1 pass-through output
The price seems to be higher than the entry levels in ONKYO or Yamaha. But, with some coupons/deals, the difference reduces dramatically (Frys had it priced at 299 until last week and online price starts at 365 including tax and shipping).
I'm wondering if there is an another brand/model that has same/better features for this price range.
Also, if anyone currently owns a Denon DHT391XP, I would appreciate their feedback about the product.
Username: Vm8444
TorontoCanada
Post Number: 328
its ok can you check my recent post
you'll see much better recommendaations from me.
budget?
theaudioguy.ca
Username: Crazylad
Vince, can you please provide a link to your recent post? I'm unable to locate it. 300-350 is my budget. I'd like to keep it as lower as possible
Username: Vm8444
TorontoCanada
Post Number: 332
wow thats low
http://www.dakmart.com/p11034/SLED-DENON-AVR-1709-7.1-SURROUND-RECEIVER-AUTH-DLR -W-WT/product_info.html
was $629 before
let me know if you do this because this combo would smoke the one you said but you must add taxes and shipping,
http://www.dakmart.com/Audio-Home-Audio-Home-Theater/c4_9_10/p11311/Boston-Acous tics-Horizon-Series-MCS100-MDNT-5.1-Speaker-System/product_info.html
these speakers list at 699
call nathely at dakmart ext.902 ok?
then use this wire believe me
http://www.crutchfield.com/p_70316460/AudioQuest-FLX-16-4-4-Conductor-16-Gauge-In-Wall-Speaker-Cable-60-feet.html
if you can't afford all at once buy a piece at a time.
theaudioguy.ca
Username: Crazylad
Vince, thank you for the details. For now, I have decided to go with the Denon DHT391XP. But, the information you provided was very useful! Thanks again for your help!
Need to Register?
Forgot Password?
Enable HTML code in message
