Trouble With PS3 and surround sound
Username: Moemore
I cannot get audio to work thru surround receiver.I have a LED tv connected to cable box via HDMI cable. I have an additional HDMI cable ran for auxiliary components. I connected my PS3 to the HDMI and tried to watch movie with it. I have an older Sony surround receiver that doesn't have HDMI outputs so I have PS3 and cable box connected thru optical cables to my receiver. Tv works ok but my PS3 does not have audio thru receiver. Does anyone have any suggestions to what it may be, I have the receiver set to the right outputs thru the dial it just isn't working.
Username: Superjazzyjames
Post Number: 955
Look in receiver manual. You may have to into a menu to tell it you want to use the optical input.
Username: Nency
Post Number: 120
Yeah, I think it's pretty stupid if you ask me that they don't have an HDMI hookup on the......
Okay, I'll try that over the weekend and see if it works. Thanks again for your help, I appreciate it.
Need to Register?
Forgot Password?
Enable HTML code in message
