Which one is better to go for
Username: Khan187
hi
need to buy a home cinema system with blu-ray. been looking at a Panasonic SC-BT230
http://www.johnlewis.com/230949039/Product.aspx
but was also thinking of getting a AV Separates instead with a blu-ray player to add to it -
had a look at the following one
http://www.richersounds.com/product/1-box-home-cinema-systems/onkyo/hts3305/onky -hts3305-blk
Do not really want to spend more the 450 on the whole unit including a blu-ray player
any one got any other ideas or can recommend something better would be a help
i will be connecting up
sky HD
Wii
blu ray player if i go for the AV system
Also have a free view box with scart connection - but wont be using it as have it built in the tv
thanks
Username: Vm8444
TorontoCanada
Post Number: 207
ok but if I give you my recommendations will you seriously consider them..
http://www.dakmart.com/p11033/Denon-AVR-1609-Home-Theater-Receiver-HDMI-1-Yr.-Wa rranty/product_info.html
or
http://www.dakmart.com/p11039/SLD-DENON-AVR-589-HOME-THEATER-RECEIVER-HDMI-1-3A-W-WYT/product_info.html
http://www.dakmart.com/Audio-Home-Audio-Home-Theater/c4_9_10/p11311/Boston-Acous tics-Horizon-Series-MCS100-MDNT-5.1-Speaker-System/product_info.html
or mix and match with any boston acoustic from same store.
bluray
http://www.amazon.com/dp/B001GAOYCS
or these
http://www.amazon.com/Energy-Take-Classic-System-Black/dp/B001202C44
hope that helps much better then yours.
theaudioguy.ca
Username: Illuminator
Post Number: 5207
I personally like that Denon one as well.
Need to Register?
Forgot Password?
Enable HTML code in message
