Some one guide me
Username: Cnu
hi everyone
i have a sony home theatre which has coaxial and optical inputs and i have to connect it through pc...i have creative sound card 5.1 channel but unable to figure out how to cnnect them.....im a novice in this area....does coaxial takes digital input....and if my sound card gives analogue out....can some body give a reasonable way to connect them to get full HD experience
thanks in advance
Username: Cnu
My sony home theatre model is DAV-DZ777 and i use creative 5.1 channel sound card Vx...hope i have given full details
Username: Jrbay
Livonia [Detroit area], Michigan USA
Post Number: 1196
Greetings,
This question would probably be better posted on the Home Theater Media Center board but my answer would be, if your sound card is analog to use the headphone jack with a 3.5mm to RCA adapter cable such as this:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804 &p_id=5598&seq=1&format=2
Username: Cnu
thanks jim
i wanna have 5.1 channel out from speaker that wud be just 2.1...though i put the speaker setup to prologic 2...still its unable to create the right surrounding and everything...its just dont work
any other ideas....thanks in advance
Username: Jrbay
Post Number: 1198
You need to check the settings for the card with the computers audio section and you need to deal with the Sony receiver settings as well. From what I can gather about your sound card it does not have a digital output correct?
Username: Cnu
Post Number: 7
yes u r right jim...it has analogue output
there are three 3.5mm output in the sound card...one for bass.....second one for left/right front and third one for left/right rear speaker
The input available on sony home theatre is
1) 3.5mm single point
2) White/Red RCA input
3) DM port
4) Coax
5) Optical
i want connect coax somehow to enable 5.1 channel.....but unable 2 figure out
thanks in advance
Username: Jrbay
Post Number: 1218
Now I see the problem the sound card is set up for a specific set of speakers and there are simply too many outputs. Is there a headphone jack located somewhere else on the computer?
Username: Satbheem
hi guys ,
i have panasonic projector , denon amp rms 75 , i need to buy
speakers for this , i had planned to do wall acoustics insulation for
better sound quality help me to by some good speakers.
i came across bose, wharfadale, difinitive, paradigm, and ordinary.
which one is better for my 12*20 feet room size
please help me i have another 10 day only..
Username: Vm8444
TorontoCanada
Post Number: 197
forget about bose sathish so what do you want speakers to look like?
bookshelves, satellites or front floorstanders and rear wall mounted or inwalls?
budget?
definitive ,paradigm ,
boston sound good..
vince
Username: Satbheem
my room is big i am ready spent around 35k rupee or $700
so which one is a good option to buy, considering the cost factor.
hw abt MONITOR AUDIO , WHARFEDALE ,
Username: Vm8444
TorontoCanada
Post Number: 201
monitor audio for sure!
and with the denon use this speaker wire
http://www.crutchfield.ca/AudioQuest_FLX_X_14_2_60_feet_14AWG_2_Conductor_In_p/7 0314260.htm
theaudioguy.ca
Need to Register?
Forgot Password?
Enable HTML code in message
