Mirage or Definitive Tech
Username: Kpax
Need to get a HT system budget around 1200.
Went and heard the demo of a lot of systems. really liked def tech pro 600 and mirage prestige nanostat.
Def tech had a better bass but mirage was nice compact. Am really confused any suggestion between these 2 or any alternative systems I should be looking at.
thx.
Username: Vm8444
Post Number: 58
check my posts bud
size ,, standmount, floorstander or wall mount?
I like boston tannoy mission
paradigm , orbs on this page sound good
reciever denon or marantz that you can afford
vince
theaudioguy.ca
Username: Razor2009
I have purchased a set of Klipsch Quintet speakers which has the FR,FL and Rear of 50w RMS and center of 75w RMS.
Have shortlisted two recievers 1 Pioneer VSX 1019AH-K which has 120w per channel and 2 Denon AVR 1910 which has 90w per channel.
As my speakers are more expensive than the reciever need some help in which reciever might be the best for the speakers mentioned....dont want to blow my speakers off....
Please suggest....am not an audio pile....thankx in advance
Username: Jrbay
Livonia [Detroit area], Michigan USA
Post Number: 1164
Greetings Razor,
Satellite: 50 watts (200 watts peak)
Center: 75 watts (300 watts peak)
The numbers mean very little actually and are very misleading as you already know. The receiver manufacturers are claiming a peak value to promote how much power they supposedly have and the speakers are rated more as a minimum effective wattage because under powering them can be very damaging.
Hope this helps and feel free next time to start a new thread!
Username: Jrbay
Post Number: 1165
audio pile - what a crack up
Username: Vm8444
Post Number: 99
hi kpax go with whatever your ears like
and
hi razor not audio pile go with the denon and set the spks to small you'll be fine.
Username: Razor2009
audio pile was a typo bro.....sorry about that.
Thanks for your response......I saw mirage mx5.1 in action and was just blown away with the amazing room filling sound from this miniature babes.....When I checked with best buy they have a mirage nannosat 5.1 for about $300 less than mx5.1
Even the mirage website doesn't give any difference between these two models.....what do u guys think ???
Am not going to keep high volume levels and be kicked out of my apartment....If am not going to find any noticeable difference I'd like to settle for the nannosats......
PLEASE ADVICE
thanks in advance.
Username: Vm8444
Post Number: 101
thought you had kliptsh??
yeah I'd go with the nano's for an apartment sounds like the sub on the other's may wake up your nieghbors...and get you thrown out.
great reviews & been around for long time for a reason.
http://www.hometheatersound.com/equipment/mirage_nanosat.htm
http://www.testfreaks.com/home-theater-systems/mirage-nanosat-5-1/
and finish the install with flex 14/2 audioquest or 16/2 speaker wire
needed to get the best out of your setup.
http://www.crutchfield.com/p_70314250/AudioQuest-FLX-14-2-14- Gauge-In-Wall-Speaker-Cable-50-feet.html
let us know how it turns out if your satisfied in the end.
theaudioguy.ca
Need to Register?
Forgot Password?
Enable HTML code in message
