Newbie: Help needed in choosing HTiB
Username: Suresh22l
Hi,
I am a newbie, could anyone suggest me a good HTiB system with HDMI inputs, with/without DVD palyer, wireless rear speakers preferred. My budget is upto 800$. 5.1 - 7.1 doesn't matter.
Currently, I own a Sony Bravia 32V300A and was looking for a HTiB. I will be taking this system from US to India. I am concerned about the voltage(220V) over there. Will it be fine if I use a voltage convertor interface.
I was also looking at few models like Sony DAV-HDX500 where rear speakers are wired :-( , Onkyo HT-SR800 as it had received good rating but had no dvd player, no upscaling of video signal, no audio conversion to HDMI. Will these drawbacks matter a lot incase of Onkyo system.
Any feedback would be greatly appreciated. I hope my questions are clear if not please let me know.
Thanks,
Suresh
Username: Press1
Yuba City, CA USA
Post Number: 303
The Onkyo is a good system, and no it will not matter. You can get other components with those features if you need them...Also, not having the DVD player can be a plus if you have a changer or other hi end player that you would rather use. IMO
Username: Jhart8
I think Panasonic makes some good HTIB systems.
My website has some suggestions for a Wireless Home Theater System
Username: Jrbay
Livonia [Detroit area], Michigan USA
Post Number: 978
Greetings,
Just for simplicity's sake I usually recommend staying with the same brand as your TV. Sometimes the different brands do not play well together.
Username: Lele
Hello!thanks for your share,I like this theme.
our-shoes.com
Need to Register?
Forgot Password?
Enable HTML code in message
