In Wall Surround Sound Speakers?
Username: Qoo527
Cleveland Heights, Ohio USA
Hi guys, newbie here. I have a 360 sq foot room with 20 feet ceiling. Im looking to install a 6.1 system and make this my movie room. 90% movie watching 10% music. I really want the sound to be crisp, can someone give me a few choices of in wall speakers? Sub woofer will not be in the wall. Looking at using the Onkyo TX-SR706. Any advice would be great!
Username: Jrbay
Livonia [Detroit area], Michigan USA
Post Number: 639
The in-walls only for the rear and back? In other words do you already have a front array(left/right/center) or are you going in-wall for all 6 7 speakers?
BTW- the Onkyo you are looking at is 7.1
Username: Mandela10
Fort lauderdale, FL
If you looking to modernize that room, you can go check out this site that give you access to some nice and elegant speakers that would fit perfectly to a home theater, check them out here http://www.jjwirelessworld.com
Username: Qoo527
Sorry it took so long to respond Jim, I am looking for rear all the speakers to be in wall minus the sub of course. Yes, I know the Onkyo is 7.1 but I got a great deal on it so I nabbed it.
Username: Jrbay
Post Number: 803
I am thinking that you have a rather large room to expect reasonably priced in-wall speakers to sound "crisp". There are several things that would be helpful to know such as what sort of video system (flat screen/projector) that you plan to use, what are the seating arrangements, how critical of a listener are you and probably most importantly what type of budget you have.
Username: Mandela10
Fort lauderdale, FL
hey guys,
I am looking for a good website or software that can allow me to create simple slideshow, if you have any suggestion, i would be really glad to hear them.
Username: Petersteel
Pyle Home PWRC82 ,Diesel Audio NS-H52 or Yamaha Micro Home Theater Receiver Sound System with Integrated iPod Docking Station, High Quality CD Player, AM/FM Radio with 30 Preset Stations, USB Port for Flash Drive, Remote Control, All Weather Indoor / Outdoor Speakers (Black) & 50ft 16 AWG Speaker Wire Yamaha Micro Home Theater Receiver Sound System with Integrated iPod Docking Station, High Quality CD Player, AM/FM Radio with 30 Preset Stations, USB Port for Flash Drive, Remote Control, All Weather Indoor / Outdoor Speakers (Black) & 50ft 16 AWG Speaker Wire ..... i would suggest these three of thm.. they are the best wall speakers that i am using it ... }
Need to Register?
Forgot Password?
Enable HTML code in message
