Sony Bravia\DAV question
Username: Sleater44
Don't think the following is possible but I'll give it ago as you guys seem to be able to work all kinds of magic.
I have the following pieces of equipment:
Sony Bravia KDL-32V2500
Sony DAV-DZ260
Is it possible to get the TV or XBOX 360 to play through the DAV speakers? Currently only the DVD can play through the DAV speakers???
The only way I think it's possible is to upgrade the TV.
Cheers.
D.
Username: Sambaughman
How can I hook-up my system to play tv sound through home theater system. I have a Sony DAV-HDX275, a Sientific Atlantadigital cable box, and an older[ approx.10 years] Sharp TV with only a coaxial cable in and 3 RCA jacks[R,W,Y]. DVD's, CD's play well but the tv sound does not play through the speakers.
Username: Jrbay
Livonia [Detroit area], Michigan USA
Post Number: 549
Take the audio out from your cable box to your Sony.
Username: Mattp
Spokane, Wa United States
"Is it possible to get the TV or XBOX 360 to play through the DAV speakers? Currently only the DVD can play through the DAV speakers???"
Unfortunately your Sony DAV system only has 1 Coaxial and 1 Optical digital input. After looking at the owner's manual for your TV it does not appear to have a digital audio output.
Your xBox 360 should have an optical digital output connection that you can connect directly to your DAV system's Optical input to hear the audio through you home theater.
Need to Register?
Forgot Password?
Enable HTML code in message
