No surround sound thru TV but DVD/VCR works
Username: Dnelson14lan
I have a Sony TV, comcast cable (but no cable box) dvd and vcr... all hooked up thru the receiver... srr sound works on dvd and vcr but not TV.. is it because there is no cable box or is there something wlse I can try?
Username: Jrbay
Livonia [Detroit area], Michigan USA
Post Number: 500
Greetings Deborah,
A possible way to solve this issue might be to take an audio out of your TV back to the Receiver with an RCA patch cable. If that is not possible due to no jacks in the back of the TV, or if it does not work, then a cable box is the next best solution (with practically no other options).
Username: John_s
Columbus, Ohio US
Post Number: 2378
Assuming You have the cable going through the VCR (cable in to the VCR and cable out to the TV), you can use the VCR's audio outputs for audio. The VCR's audio must already be hooked up, otherwise you wouldn't be getting surround from the VCR.
Username: Levelzero
Post Number: 75
What cable are you using to connect the TV to the receiver?
Also, be sure you're seleting the appropriate speaker output through the television's menu screen.
