Whats wrong? please help
Username: Ishkabobble55
Erie, Pennsylvania
Post Number: 240
ok so i hooked up some new speaker to my sony reciever its the model number str-de635 and all the sudden it went into protection mode and now when you turn it back on there is no sound coming out of any speakers and if you turn it up all the way the sub makes very little sound... i tried resetting it and that didnt work, what can i do???? please help if you can.
thanks, Ac
Username: Project6
Post Number: 7214
If you connected speakers with an impedance rating other than 8 ohms or higher to that receiver, you may have put it on protection mode permanently. This can also be caused by speaker wires being crossed. Check the connections and reset.
Erie, Pennsylvania
Post Number: 241
how do i get it out of protection mode, ive already checked all of the connections and reset it? thanks
Username: Project6
Post Number: 7215
What was the impedance rating of the speakers that you used?
Erie, Pennsylvania
Post Number: 242
4ohms
Erie, Pennsylvania
Post Number: 243
there was actually two speakers to one channel and i switched the polarity on one of the speakers
Username: Project6
Post Number: 7216
Unfortunately by doing what you did, you have damaged your Sony receiver. That unit is not designed to handle low impedances.
time to shop for a new unit.
Erie, Pennsylvania
Post Number: 244
so there is nothing i can do, i cant take the metal covers off and replace something on a circut board or nothiong?
Username: Project6
Post Number: 7218
Unless you are a technician, no.
Erie, Pennsylvania
Post Number: 246
actually i just took the unit apart and found two blown fuses that i am soon to replace, so that would fix it right?
Username: Project6
Post Number: 7222
Hopefully the replacement of the fuses will solve your problem. Others have not been so lucky. Just make sure that you replace them with the same value.
Good luck.
