I need help setting up
Username: Ocni123
I have a TV DVD Player, DVD recorder and sattelite and i cant seem to hook up properly can someone help??????? Thanks
DVD to TV video: component (red,green,blue)or S-video is your TV lacks component inputs
DVD to TV sound: red/white RCA's
Sat to TV video: S-video
Sat to TV sound: red/white RCA's
For the DVD recorder you will need an input and an output.
Recorder to TV video: red,green,blue or S-video
Sat into recorder video: S-video or yellow RCA
Recorder sound IN/OUT: red/white RCA's
This setup is only a guess as you did not specifiy the specfic inputs per your equipment. This setup lack digital sound but I'm assuming you have no hometheater receiver of other audio device that will play digital sound, therefore, I kept this setup analog only. Hope this helps you some.
Username: Bch
Pacifica, CA US
I just got a home theater and HDTV (via cable). Everything works except the DVD/VCR. It apparently is not connected properly. Can anyone help me with the hookup? Here is my equipment:
Cable box - Motorola (from Comcast)
Home Theater receiver - Sony HT-DDW665
DVD/VCR - Sony SLV-D350P (bundled with receiver)
TV - Sony KV-30HS420
Username: Cgabe3607
Escondido, Ca USA
Post Number: 7
need help with connecting Bose lifestyle 28 home theater to my Panasonic plasma HD TV. HDMI connection not compatable with Cox cable. With component cable connection I hear only one left speaker of my Bose system
I need help connecting my dvd surround sound system to my dvd recorder to my tv can some one help me my dvd surround sound is a regent
Username: Project6
Post Number: 5668
http://www.ce.org/connections_application/
Username: Dirtfarmer
Alberta Canada
Post Number: 664
berny
where did you find the site
petty good
arnie
Username: Project6
Post Number: 6249
Arnie,
Some other regular posted it here and I kind of kept it in mind to help out the new HT fans without having to post the same stuff again and again.
Username: Chitown
Post Number: 777
The only problem with it is that somehow it does not work with FireFox.
Alberta Canada
Post Number: 668
Stof
use this link on firefox
http://www.ce.org/connections_application/CEA_Connections_Guide_Final_v2.swf
it work
for some reason this link
work good on IE but not firefox or mozilla
also i went to main site
http://www.ce.org
and i can seem to find where ther got the guide in the first place
also
you have to add a couple of plug in to firefox like flash or shockwave
https://pfs.mozilla.org/plugins/?application=firefox
Username: Chitown
Post Number: 783
Correctomondo. Firefox it is
Thanks.
Right, I am a total technophobe here, so I hope someone can help me.
I have a Grundig digibox, and have just bought a Panasonic DMRES20 for my son, which he has in his bedroom.
I run a coaxial outside the house up to his bedroom, and it plugs into the 'RF In' on his DVD recorder. This allowed the freeview channels on the DVD Recorder to all set up properly, but it does not set up a channel for the satellite signal. We have temporarily got round this by manually setting up a channel on the DVD recorder for his video recorder, and watching that with the video recorder set to the satellite channel. This causes a slight loss of picture quality though, and it would be much better if the DVD recorder was set directly to show satellite output. It is impractical to run a scart lead from the digibox downstairs to the DVD recorder upstairs.
Can anyone offer advice?
