Neat wiring install
Username: Patenl
Post Number: 9
Who can point me in the right direction.....want to have wall plates or jacks that I can make speaker wiring cleaner from the wall to the speaker....also all the wiring from input of TV (DVD,SATELLITE,VCR)coming from the wall...is there a wall plate for this so having little patch cords so it makes it cleaner?
thanks
Luc
Username: Colehill
San diego, Ca Usa
There are many ways to clean up your wiring installation. A few suggestions are to purchase wall plates that allow you to terminate the wire on the backside, and have clean connections on the veiwable side that feed directly into your components, and the other simple solution is to use snake skin covering or similar products. Look at these sites. http://www.action-electronics.com/loom.htm or http://www.uniqueproductsonline.com/4pospwaplfor.html
