Brad
Username: Joebruce
TC Sounds/DLS
Post Number: 2587
Hey man I was wondering if you could help me out. My computer is majorly f*cked! Im not sure if it was something I downloaded or what but I can barely even use it. I get all these pop ups at the bottom right hand corner telling me my computer is at risk and a bunch of other things. I tried running AVG but it wont let me finish a scan. Then it installed some kind of antivirus program by itself and keeps telling me I have to buy it or something. I have some programs from Uniblue called SpeedUpMyPC and Registry Scanner,I ran them both and the reg scanner said I have like 550 reg. problems. I clicked on fix,but then the Registry Editor window keeps popping up and wont let me close it. And it will not let me fix the problems. Sorry I know Im typing alot but I dont know what to do man. I would like to just do a system restore but when I click on it it does nothing. How can I just restore the factory settings and wipe everything out and start fresh? I have a Dell Deminsion E510. I read somewhere to press ctrl+F11 at restart but that doesnt do anything either. If you have a min to read this please help me out. Thanks.
Username: Joebruce
TC Sounds/DLS
Post Number: 2588
Another thing,when I log on and all the startup programs begin,I get two windows that pop up and tell me my Cham. Clock has a virus and to scan it first. And the other window says the same thing about my CursorFX. Well I'll be on AIM if you are around.
Username: Joebruce
TC Sounds/DLS
Post Number: 2589
CursorFXexe-App. Error
The exception Integer division by zero.
(0x0000094) occured in the app. at location 0x0040dfa3.
Click OK to terminate the program
Click Cancell to debug the program
C:\program files\chameleon clock
Files Corrupted!
Please run a virus check,then reinstall the app.
Username: Wolf_hound
Phoenix, AZ
Post Number: 918
this thread sucks im requesting it be deleted in the suggestions section...
Username: Joebruce
TC Sounds/DLS
Post Number: 2590
Ok Brad I re-installed Windows XP and everything is back to normal,for now. Could you get me some programs so this will NEVER happen again? I seen your list of security programs in that other thread,if you could get me some links/serials for them that would be cool. Also if you have some time I need the following programs along with the serials.
ConvertXtoDVD
DVD Shrink
CloneDVD
Nero
Jet Audio
Winrar
and whatever those Codecs were that you linked me to awhile back
Thanks again man.
Username: Joebruce
TC Sounds/DLS
Post Number: 2591
Sorry,one more thing. I had to call my Internet provider to get back online and they said I need to install my ethernet card drivers. Im connected now through a USB cable to my modem. They said that this way works but its better to use the ethernet cable. I have no idea how to install the drivers or what to do after I install them.
Username: The_image_dynamic
San Diego, California
Post Number: 5183
You did a repair like I told you right? That was your only option since nothing would run or install right.
Your ethernet drivers are on your motherboard cd. If you don't have it go get cpuz here:
http://www.cpuid.com/download/cpuz/cpuz_151_setup.exe
Start it, click on the Mainboard tab and tell me what make and model motherboard you have. I will show you what to do after that.
Username: Joebruce
TC Sounds/DLS
Post Number: 2592
Manufacturer-Dell Inc.
Model-0HJ054
Username: Big_edge_head
Milwaukee, WI
Post Number: 3897
lmao stfu julian
Post Number: 5185
http://support.dell.com/support/topics/global.aspx/support/downloads/en/download s_splash?c=us&l=en&s=gen&~mode=popup&file=150654
Username: Joebruce
TC Sounds/DLS
Post Number: 2593
Thanks but now what? lol
Post Number: 5186
Plug an ethernet cable from your cable modem to your network card -- or your computers ethernet input if you don't have a card, and reboot.
Username: Joebruce
TC Sounds/DLS
Post Number: 2594
Cool thanks.
Can you hook me up with the codecs that Ill need to play my movies I DL?
Post Number: 5187
http://download.cnet.com/3001-2141_4-10013740.html?spi=f1dbf3abccd534aa03ebd1257 dedee6d
http://www.free-codecs.com/download_soft.php?d=4206&s=67
And get Opera too -- IE is probably what got you into this mess in the first place:
http://www.opera.com/download/get.pl?id=32022&thanks=true&sub=true
Username: Joebruce
TC Sounds/DLS
Post Number: 2595
Thanks once again!
Oh and Opera was the FIRST thing I downloaded.
Username: Jtown
Texas
Post Number: 3800
Hey twiz, is CloneDVD a program you can use to copy copyrighted DVDs? I need one of those.
Post Number: 5199
http://rapidshare.com/files/198321212/DVD.X.Studios.CloneDVD.v4.3.0.2_www.softar chive.net.rar
Username: Jtown
Texas
Post Number: 3802
hey brad, thanks for the link but i seem to be having some problems with it. I tried extracting it and got nothing, then zipping and extracting, nothing. I tried opening it with poweriso to no avail. What do I do?
Post Number: 5202
It's a rar file -- almost everyone uses WinRar nowadays to compress files.
Get this free extraction utility to open it:
http://downloads.sourceforge.net/sevenzip/7z465.exe
Username: Jtown
Texas
Post Number: 3807
Hey Brad, sorry I took so long. Just wanted to say thanks for the help!
Do you have a link to good DVD playing software? Mine was lost and couldn't be recovered or transferred when I had HDD problems.
Thanks again!
Post Number: 5221
http://rapidshare.com/files/149699414/DVDX-Playe-4.1.rar
Username: Pitbullguy
The Chicago area
Post Number: 3902
Brad Warren; living proof that chicks dig computer geeks.
Username: Jtown
Texas
Post Number: 3808
Thanks again!!! I'll prob get this setup later tonight.
Pit, hot chicks at that!
Username: Joebruce
TC Sounds/DLS
Post Number: 2611
Yo Brad could you get me a link for winrar? All I have now is the trial version.
Username: Joebruce
TC Sounds/DLS
Post Number: 2612
Oh yea and how the f*ck do I use the crack that came with CloneDVD? I cant remember how to do it and I dont wanna f*ck it up by trying it lol.
Post Number: 5267
Just use 7-zip for .rar and everything else, it works great:
http://www.7-zip.org/
As far as the Clone crack I don't remember what it was but you most likely just copy and paste the crack (replacement exe) into the folder where the program installed and replace the old one.
Username: Jtown
Texas
Post Number: 3890
hey brad, I'm not sure how I did it before, but I can't get that copy of clonedvd to run. It says my trial version has expired. I'm not sure how to "re-crack" it, or do I have to download another version?
thanks for the help, sorry for the complications.
Username: Joebruce
TC Sounds/DLS
Post Number: 2626
Yo Thieves I figured out how to "crack" CloneDVD. I did it like last year or somethin but I forgot but I remembered how to use it again lol.
right click on start
explore
program files
clonedvd
drag the dll file from the download and put it in the clonedvd file
it should say something like "file already exsist do you want to replace" hit yes
start clonedvd and it should be good to go!
Username: Jtown
Texas
Post Number: 3891
thanks man, I thought it had something to do with that but I couldn't get it to work for me.
but it's up and running, I appreciate the help twiz
Username: Joebruce
TC Sounds/DLS
Post Number: 2629
No problem man! I got learned by Brad so really we should be thanking him lol!
