Help please - electronics techheads
Username: Madboy
Hi
Appreciate this forum might not be the best one to ask this question in (if it's not, can anyone point me in the right direction?)
I'm trying to marry a cheap PIR motion sensor security light to a wireless doorbell. As in, motion sensor is tripped and doorbell rings. I was intending to wire the output from the motion sensor (normally to light bulbs) to the switch on the doorbell.
However, it occurred to me that it's 240v AC going into the light bulb and a 12V DC battery running the doorbell. I assume I'd fry the poor little circuit board if I sent that voltage into it.
Without spending any money, how can I get around this problem?
Can I hack up a phone charger and use it to step the mains power down to 12v? Or will that still be too much for the doorbell circuitboard?
Reason I'm doing this is that I'm too cheap to spend $278 buying the proper off the shelf unit.
Any suggestions or pointers would be appreciated. Thanks in advance.
Username: Nd4spd18
Philadelphia, PA
Post Number: 10561
So you need a 240vac to 12vdc transformer.
Now where are you getting 240v from.... not in north america perhaps?
Username: The_image_dynamic
San Diego, California
Post Number: 5257
With the 240VAC and the use of the word "proper" I would say he is in the UK somewhere.
http://www.tlc-direct.co.uk/Products/LTYT50.html
Username: Madboy
Hi. New Zealand. We use the Queen's English here ;)
So would a mobile phone charger (I have heaps of them lying around from various phones I've had over the years) not be suitable? Is it because they would have a fixed output not a variable one?
I'm just trying to think of what I can get fast and cheap! Thanks.
Post Number: 5259
Ahhhh NZ, love that place. We trout fish at North Island as often as we get out there. And all the hot blonde girls my goodness....
Yes, depending on the milliamps that the light can handle, a phone charger will work. Find the lowest mA@ 12V output one you have and try that. Depending on how far it is from the 240V, you can always sacrifice another PS's wire and patch that length on to whichever one works.
Username: Van_man
Boston South, MA
Post Number: 4909
I think a simple relay wired in would accomplish your objective.
