Difficulty
Username: Jan_b_vigne
Dallas, TX
Post Number: 4790
I have had a problem posting of late. After I had registered on the forum, my name and password were automatically loaded when I enterd the forum. Now the name and password are missing and need to be entered manually before the forum will accept a post. Can this problem be rectified?
Username: Joe_c
Oakwood, Ga
Post Number: 823
It is probably your pc Jan, problem with cookies and remembering passwords.
Moderator
Username: Admin
Post Number: 591
Try to clear your cookies, and clear any saved passwords?
Which web browser are you using?
Username: Joe_c
Oakwood, Ga
Post Number: 833
You think anymore about the moderators Admin?
Dallas, TX
Post Number: 4801
I'm using Yahoo DSL.
Username: Joe_c
Oakwood, Ga
Post Number: 842
No Jan , he means Internet Explorer, Netscape, Mozilla. That sort of thing.
Dallas, TX
Post Number: 4805
Yes, I know. Yahoo DSL has their own browser. (http://dsl.sbc.yahoo.com/) Their intial set up is through InterNet Explorer, but no one I know with Yahoo DSL uses I.E. The two browsers do not resemble one another at all.
I've cleared the cookies and Temp Internet files and the username/password problem persists.
Dallas, TX
Post Number: 4807
OK, I've cleared the saved passwords and signed into the the forum. For some reason the username signs on each thread as "JAN+B+VIGNE" and I get an error message when I try to post which says my username/password are too close to a registered member.
Moderator
Username: Admin
Post Number: 592
The Username you should be using is "Jan_b_vigne" (with the underscores).
If you leave the password blank, the forum attempts to post as an "unregistered user", which is likely the cause of the error you are seeing.
Once you login correctly, a temporary cookie is set on your computer to keep you logged in.
Dallas, TX
Post Number: 4820
The username seems to work fine. Thanks.
However, for the past few months since I registered, I have not had to log on when coming into the forum. I now must log in every time to be recognized by the forum for posting. Am I still missing something? Is there an automatic recognition of my computer that is now missing?
Moderator
Username: Admin
Post Number: 593
Check your profile.
https://www.ecoustics.com/cgi-bin/bbs/board-profile.pl
Make sure there is a check in the box: "Remember my username and password in a cookie"
Username: Stereo_genious
Post Number: 61
Hey, does anyone know how I can re-type my full name and e-mail address? I typed wrong during registration. My real name is Matt. I typed Mike by mistake. Any suggestions?
Moderator
Username: Admin
Post Number: 594
You can edit your full name and e-mail address after logging into your profile:
Dallas, TX
Post Number: 4833
I went to the edit profile page and found the save username and password checked. I cleared and rechecked the boxes (twice) and hit save changes. I'm still not being recognized when I enter the forum. Any suggestions?
Moderator
Username: Admin
Post Number: 596
Are you using internet explorer, netscape, mozilla, safari, or opera web browser?
Dallas, TX
Post Number: 4869
Yahoo DSL. Yahoo DSL has their own browser. (http://dsl.sbc.yahoo.com/) Their intial set up is through InterNet Explorer, but no one I know with Yahoo DSL uses I.E. The two browsers do not resemble one another at all.
Username: Joe_c
Oakwood, Ga
Post Number: 867
It is I.E. based Jan. May look diff and work diff but it's foundation is I.E.
Dallas, TX
Post Number: 4878
Probably is. But I don't know what that implies to the actual operation of the two browsers when trying to resolve a problem such as this.
Dallas, TX
Post Number: 4887
I've cleared all cookies and temp files (under both IE and Yahoo) once again and the problem with remebering my identity still persists.
Dallas, TX
Post Number: 4889
Test.
Dallas, TX
Post Number: 4890
Test.
Dallas, TX
Post Number: 4891
OK. Seems to be working after I went to the profile and unchecked/checked/saved profile changes once again. We'll see what happens.
