Nfusion solaris adding tp nfps
Username: Tasmanian_satellite
Post Number: 166
hi..i have a nfusion solaris on nfps and noticed lately that i do not receive a lot of channels and was reading that channels from 110moved to119 and channels from 119 moved to 110 how can iadd new tp to my system.. i would need step by step instructions
thanks
Username: Mrgreg
Post Number: 1485
Factory default and rescan.
Post Number: 167
Hi what do you mean factory default ,would i have to start over and program tboris, nfusion loader etc,thanks
Username: Mrgreg
Post Number: 1486
You can rescan without defaulting but you will probably end up with duplicate channels.You can delete the duplicates.I do not own a Nfusion so I can not tell you if defaulting takes your programming out but most receivers do not.
Diamond Member
Username: Nydas
Post Number: 23251
There is no default list, unless you go to a site and download a list.
1. Select one satellite at a time.
2. Delete all channels.
3. Scan the selected satellite.
4. Delete selectively the ones you do not want.
5. Repeat all for above for the next satellite in the list.
Post Number: 168
sorry i am so confused by all this.. is there step by step instructions for this i've been looking through the menu i dont see where it says 110 and 119.can you please explain this to me i really appreciate it.
thank you
Diamond Member
Username: Nydas
Post Number: 23252
You will see all the satellites mentioned at this URL.
110W and 119W means the longitude west Of Greenwich, England.
For these two longitudes you are looking for Echostar10/11 and Echostar 14, in your receiver.
Some of the details of each are available through the Packages at:
http://www.lyngsat.com/america.html
I notice that Echo 10/11 and Echo 14 details are not available today. I am not sure why. It could be that there is a temporary blackout because of a electrical storm, but I can't seen why Lyngsat would not show the list. I would wait for a day or two, to see if the full list is available through the last URL I gave before deleting anything.
Somebody actually using the same receiver as yours might give a better answer.
http://www.lyngsat.com/packages/america.html
Post Number: 169
Is there anybody out there that has the same receiver as me on tboris software that can help with the question i have asked.
thanks
Username: Mememememe
Post Number: 322
Need to Register?
Forgot Password?
Enable HTML code in message
