Flashing lights on Sharp AQUOS LC-70LE732U
Username: Timeyman
I purchased a Sharp AQUOS model # LC - 70LE732U, serial #104823170. it's a black screen, with the power/arrow light below the word Sharp at the bottom is flashing. 5 successive white flashes, then a pause, then 2 white flashes, then a pause, then back to 5 flash sequence.
when I manually push the power button on the right side of the TV, the power/arrow light will stay lit up in white for several seconds, then switch to the 5-2 flashing sequence.
Purchased in May, 2011. suggestions?
Username: Ldavis974
Port St Lucie, FL United States
Having same problem with my 60" that I bought about a year ago....Samsung seems to be the answer I think
Username: Bekma
Similar problem and I just bought mine in April. 2 flashes and 3 quick flashes. LC-70LLE734U stays on briefly and then shuts off. Did you find out the problem?
Username: Magfan
Post Number: 2810
The manual will list the 'code'.....
If they manual does NOT have this info in the troubleshooting section, it's a worthless book.
At that point, you need to write a note to service or call a local authorized tech.
Even if the answer is sort of generic, it's a place to start troubleshooting.
Need to Register?
Forgot Password?
Enable HTML code in message
